Need a little help diagnosing this chirp... video included
Old Nov 8, 2020 | 02:10 PM
Brandon318's Avatar
Default Need a little help diagnosing this chirp... video included
Can you guys give me a hand? Occurs only on cold start and goes away after 20 minutes.
Old Nov 8, 2020 | 07:45 PM
Red5's Avatar
Sounds like a dry pulley to me. Remove the belt and spin all of them by hand. If any spin freely with no resistance at all, they should be replaced or cleaned and repacked with fresh grease.
Old Nov 8, 2020 | 07:46 PM
Extinct's Avatar
belt, or maybe a bad idler bearing
Old Nov 9, 2020 | 03:16 PM
nashvegas's Avatar
Hey Red5 - question - You can repack these pulleys with grease? Any info on how? I thought they were sealed? (I've replaced one awhile ago because it was noisy like the OP's)
Old Nov 9, 2020 | 05:53 PM
Extinct's Avatar
No repacking, you can replace the bearing for less than $10 if you have a press, except for the tensioner pulley as it is plastic and bearing is molded in.
stillruns
Sights N Sounds
Oct 2, 2019 10:12 PM
albertdefender
Defender
Feb 20, 2014 05:50 AM
Fivespddisco
Sights N Sounds
Nov 22, 2013 04:16 PM
Spike555
Sights N Sounds
16
Sep 18, 2013 06:00 PM
Fivespddisco
Sights N Sounds
Nov 13, 2012 08:45 PM
