Need a little help with this one...
Old Oct 10, 2011 | 12:25 PM
Straight Shooter's Avatar
8th Gear
Default Need a little help with this one...
I just finished doing the head gaskets on my 04 Disco and everything went well but when I start it cold, it idles really low. Before when I would start it cold it would idle at around 1200 and then drop down and now it is around 700ish. it idles smooth and not missing at all. Any suggestions??? I cheched all connetions and everything looks good. I do have a small leak around the SAI pipe but have another on the way to replace that. Thanks Jim
Old Oct 10, 2011 | 02:15 PM
How about fault codes, if so what are they?
Any white smoke on cold starts?
Old Oct 10, 2011 | 03:16 PM
8th Gear
Thanks Mike for the quick reply....no I have got no fault codes and no smoke of any kind.
Old Oct 10, 2011 | 07:20 PM
Your idle air control is out of whack, give it a weeks worth of driving to reset itself.
If it does not re-adjust then you will need it reset.
Make sure it is plugged in to.
twoxred
Sep 23, 2010 02:24 PM
davidlafrance
May 12, 2010 09:39 PM
Rover Curious
Mar 20, 2009 04:45 PM
LPs HSE
Jun 19, 2007 09:12 PM
love2disco
May 10, 2007 10:38 AM
