need recommendations for 12 point socket kits for caliper job
Prepping for a brake overhaul next week and I need 2 12 point metric sockets for the caliper bolts: 13 mm and 19 mm. Anyways I'm looking to expand my tool collection (gradually) without spending a fortune, so I'm looking at getting a 10-15 piece 12 point metric socket set and wanted to know what and where you guys got yours. I found a nice set on amazon last week for $40 and it had both the 13mm and 19 mm 12 point sockets..... but forgot to bookmark it and now I can't find the bloody thing!
FYI I'm using this source for a guide to my upcoming brake job:
DIY: Part I — Replacing Rear Rotors and Brake Pads on a Land Rover Discovery II - MAVROMATIC
DIY: Part II — Replacing Front Rotors and Brake Pads on a Land Rover Discovery II - MAVROMATIC
I used a standard craftsman socket set and it worked fine. If I remember correctly, deep sockets are not required. As an aside, I always crack the bleed screw when compressing the caliper piston to replace the pads. I have heard running brake fluid through the ABS modulator backwards can cause problems, so I avoid it altogether by bleeding. Remember to bleed after the brake job to make sure you get out any air in the system. Just follow the Rave procedure and you will be okay.
Which pads/rotors did you go with? I opted for the Akebono Ceramic Euro pads with EBS dimpled/slotted rotors. Never stopped better, and no brake dust!
Land Rover Discovery II Brake Rebuild Kits: Land Rover Brake Kits Online
Brake Master Cylinder (SJC000110 Same Fit As Part # PMN222) - Land Rover hydraulics from Atlantic British
Caliper Guide Pin Kit - Front (Genuine Part # STC1920) - Land Rover hydraulics from Atlantic British
Caliper Front RH (Part # SEG000030) - Land Rover hydraulics from Atlantic British
Caliper Front LH (Part # SEG000060) - Land Rover hydraulics from Atlantic British
Castrol Brake Fluid For land Rovers And Range Rovers
Dirtnap
11-03-2013 02:27 PM
zracin
07-31-2011 03:43 PM
