need some engine help guys (rod and main bearings)
Old May 6, 2011 | 08:09 PM
Bundu's Avatar
Banned
IMO you are going down the wrong road.
I have a 2003 and did a complete rebuild on an engine, it ticks. That sucks but I'm not sweating it, just keep on driving.
Old May 6, 2011 | 09:25 PM
jck09's Avatar
Thats why im not rebuilding the 4.6 out of the 03. I bought a 4.0 out of a 99. Are you thinking im going to have problems with he 4.0 as well? What road would you suggest i go down? Living with the tick/knock is not an option for the wife so i have to figure it out.
Old May 6, 2011 | 09:56 PM
buick215's Avatar
Tell your wife to turn the radio up. Seriously most Land Rovers have the tick. Is it normal and OK, no but most people have driven with the tick for over 50k miles and have not had any problems. You are going to spend a ton of money and in the end you might have the tick come back before you know it. Mine doesn't have the tick but if it developed it I probably wouldn't replace or rebuilt the engine unless it was something serious. It just isn't cost effective, our trucks aren't worth much any more.
Old May 6, 2011 | 10:39 PM
jck09's Avatar
I probably wouldnt rebuild it either if i had more than 4 psi oil pressure at idle.
Old May 6, 2011 | 10:43 PM
jafir's Avatar
If you've got only 4 PSI, then your knock might not be the same ticking that everyone else has learned to hate.
Old May 6, 2011 | 11:01 PM
buick215's Avatar
I did not know that you only had 4 psi of oil pressure at idle. That changes the whole story.
Old May 6, 2011 | 11:08 PM
jck09's Avatar
Yeah 4 at idle and 32 at 2000 warm. weird numbers. do you think the bearing cap that had no bearing in it needs replaced?
Old May 6, 2011 | 11:13 PM
buick215's Avatar
I wouldn't mess with your engine since it's a 2003 and has oil pump related problems on top of that. I would look for a 1999-2002 engine like you are considering, good luck.
Old May 6, 2011 | 11:15 PM
jafir's Avatar
Keep most of the 4.6 stuff though, if you can. If eventually your new-to-you 4.0 starts acting up, you can use the good block from the 4.0, and the 4.6 crank and build yourself a good 4.6
Old May 7, 2011 | 06:58 AM
vandev's Avatar
Default options
I know wher you can get a 4.6 completly rebuilt ready to drop in for $2,500.00.. if you dont want to mess with it.. I will post a thread later with the details... It's a friend of mine that owns a pretty large indy rover shop...
Chris
