Need some help with a sound (video)
Old Feb 16, 2011 | 05:01 PM
jhewitt1111's Avatar
Default Need some help with a sound (video)
Well I was doing some things today to figure out my codes, per mike. I fired it up and there was a high pitched while/sequel from the throttle body. I am posting a video to see if anyone can catch it. Is that the sound of a vacuum line, or something on the throttle body. I took it apart, cleaned it, checked all the connections, put it back together, and still she whines... Any thoughts.
http://www.youtube.com/watch?v=VwtSLp3hXbc
Old Feb 16, 2011 | 06:38 PM
Remove the serpentine belt, start the engine and listen for the noise again.
Old Feb 16, 2011 | 06:52 PM
photocrimes's Avatar
I suspect a bearing somewhere but searching for a vacuum leak I usually use a unlit propane torch. Just crack the valve and move it around the area in question. When you get close to the leak the engine will rev up a little.
Old Feb 16, 2011 | 09:27 PM
That is crazy. But it does make since.
Old Feb 16, 2011 | 09:31 PM
Old mechanic trick, works like a charm.
texmbr's Avatar
I watched a mechanic at a shop use a Bic lighter moving it around close to the vacuum connections....and it worked. Unlit of course.
DISCO JAK
Oct 7, 2013 09:06 PM
Jared9220
Oct 30, 2012 04:23 PM
0304Disco
Sep 1, 2011 03:28 PM
Billabong
Jan 27, 2010 12:36 AM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
