need a specific bolt/screw...
Old 09-08-2010, 09:37 AM
agthird's Avatar
Default need a specific bolt/screw...
and land rover does not sell them...it's the bolt/screw that holds the fan shroud in place there is two on the top part of the shroud and two on the back side lower shroud....anyone have a source?....I would like to use ome if possible...
Old 09-08-2010, 10:40 AM
Bundu's Avatar
Banned
Visit Home Depot/Lowes/Autozone/Advance with one of your screws, its just a sheet metal screw.
Old 09-08-2010, 10:42 AM
lipadj46's Avatar
They are not sheet metal screws but a sheet metal screw will work.
Old 09-08-2010, 10:44 AM
ShortTom's Avatar
+1. They are very very course threaded (like two threads on the whole screw). Actually I think a sheet metal screw may hold the shroud a little more snugly.
Old 09-08-2010, 10:47 AM
lipadj46's Avatar
They also have a nub on the end to keep them (most of the time) from falling out of the shroud. Honestly I don't think they are even needed.
Old 09-08-2010, 10:52 AM
sloan74's Avatar
Yeah bring the bolt to Lowes and they have a wall plate full of threads so you can screw it in and match it, and go from there, etc.
I just did the same this weekend, replaced the transmission filter and the bolts were old so I got new ones. M6 was the Lowes thread size (10mm head).
________
Medical Dispensaries
Old 09-08-2010, 12:31 PM
Bundu's Avatar
Banned
OK sorry for the technical fubar about sheet metal screws, it's just a freaking course threaded screw that you can find anywhere, geez....
Old 09-08-2010, 12:59 PM
agthird's Avatar
geez I know....was looking for a freaking oem one that's all...
Old 09-08-2010, 01:15 PM
agthird's Avatar
lol...the shroud is two pieces it may fall out the bottom with my luck....
Old 09-08-2010, 06:17 PM
Go to True Valve and buy a nut and bolt and a lock washer, one set for each side.
The lock washer will keep the nut from falling off which will keep your fan shroud from falling off.
Total cost $5.
If you use stainless steel nuts and bolts it wont rust.
Quick Reply: need a specific bolt/screw...
