NEED TRAVEL HELP ! ! 03 Disco II
Hello guys,
I'm about to embark on a road trip, roughly 1,000 miles or so.
going to change brakes and oil. What else should I be aware of, or check?
My "three amigos" are in full affect as well, but thats another thread...
Also would it be ok to use the BrakeBest(cheap) pads for the job?
This is my first rover, LOVE a challenge! thanks in advance.
I don't know what little quirks your disco might have, but two things I would suggest would be to first, at a minimum grease the front drive shaft, and secondly, as a precaution, I would carry some premix coolant, some oil, a set of metric wrenches, flashlight and other assorted tools.
Also, I can't stress enough how much information you can gather by reading over the stickies found at the top of the page. They're there because a lot of people have had those issues, so sooner or later, you might have them as well.
Hopefully, you've logged a few hundred miles, just to get a feel for your truck. They can be quirky. There's no info on how many mies are on your Disco, general condition, etc. Three Amigos on constantly is something you need to address. Also, as mentioned, front drive shafts, if original, can be a ticking time bomb (though I suspect some of the catastrophic failures cited again and again on the forums are the stuff of urban legend).
Keep an eye on temps and oil level, and good luck.
DRW
DRW
Carry a case of bottled water in case you have a leak, otherwise you can drink it. Do not drive overheated. The loss of a front shaft with little or no warning is possible, and some owners got it covered by insurance because they hit something (pothole, road trash). If you have a code scanner that reads live data you can plug that in and drive with it.
Road trip haah.......I hope you mean you have a roof tent and you are going into the mountains......Tell me yes... Otherwise..rent a car for $20.00 a day that gets over 30 mpg ..... save yourself $300.00 in gas and enjoy yourself not thinking about your truck breaking down. The plus is you can drive your rent a car like a rent a car... otherwise you better take your black American Express card....
I drove my 190k+ Rover on a 2500 mile 3 day trip to see a heavy metal band I had never heard of before, only problem I had was replacing a POS AutoZone rebuilt alt in a church parking lot in Norman OK during the Annual Norman Music Festival with a $10 socket set and a Swiss Army knife on the return trip.
I will make notes of all the advice, and will look into the Akebono pads.
Sorry , thought I typed the info. 2003 Disco II 76,000 miles. Had it for close to a month now, got it at a steal because all these problems terrified the previous owner!
Three amigos shining bright( looking over the abs fix posts now.) Just replaced the front door regulators.(easy-peezy!) And the crank position sensor. My "NEED" to fix list still includes; front doors lock solenoids, front sunroof motor, front fog(hella)lights, dont work. Pointers in any of these directions will be greatly appreciated as well.
