NEED TRAVEL HELP ! ! 03 Disco II
Old 03-11-2012 | 09:03 AM
BradSwanson's Avatar
I agree that the brakes are not a place to cheap-out on with a Landy; they weight too much.
Old 03-11-2012 | 11:18 AM
Does it need brakes right now?
If so buy whatever is in your budget, I have Duralast middle of the line brake pads on my truck, they work just fine.
The biggest thing you need to worry about is the front driveshaft, if it has not been rebuilt yet you need to get that done, and I would also replace the crank position sensor, if either of those fail they will leave you stranded.
Other than than, change all of your fluids and go.
Old 03-11-2012 | 07:44 PM
Moosebilly's Avatar
4th Gear
Crank position sensor done, whats involved in rebuilding the drive shaft? Is it a do it yourself project?
Old 03-11-2012 | 07:51 PM
Check the write up section, you can do it yourself, most have it done, its easier that way.
Remove the front driveshaft, take it to a driveline shop to have rebuilt, reinstall.
You will need to park your truck for the day.
Old 03-12-2012 | 04:45 AM
antichrist's Avatar
I don't know about "easier", but it's certainly cheaper.
Old 03-16-2012 | 10:50 PM
Moosebilly's Avatar
4th Gear
18 mpg! ! Not too shabby... There's hope for this beast yet!
Old 03-17-2012 | 08:45 AM
Don't adjust anything!
Attached Thumbnails NEED TRAVEL HELP ! ! 03 Disco II-fuel_gauge_in_dollars.jpg
Old 03-17-2012 | 01:33 PM
G Reeves's Avatar
I have an '03 that I regually drive from Baltimore MD to Ocala in FL and when towing get 15 MPG and on its own get 19.6 mpg. Do the drive shaft and the only other spare that I carry is the serpintine belt. As for breaks I went with Akebono pads on standard rotors and would not hesitate to fit them again. I even fitted them to SWMBO volvo xc70
Old 03-17-2012 | 02:07 PM
RedAustinIX's Avatar
I've posted more details somewhere here on this forum, but last summer I took my family of 4 and a whole bunch of gear on a 4,500 mile road trip in my '03 Discovery. The only problem was a flat tire. At a minimum, I suggest the following:
1) AAA card
2) 1 gallon Dexcool (or whatever you're using)
3) 1 quart oil (whatever kind you're using)
4) Duct tape
5) Nitrile gloves, paper towels, etc.
Make sure to check your fluids at every gas stop. It's not a bad idea to check your tire pressure every morning to optimize your gas mileage.
Don't sweat it... Discovery's are great! And I hate driving rentals...
RedAustinIX (Ed)
Old 03-17-2012 | 11:23 PM
vandev's Avatar
Default You forgot something...
1) AAA card
4) Duct tape
RedAustinIX (Ed)
Rentals are the best as you can drive them ...........like a rental....Don't forget your glock so you can put a bullet in your head just before you loose it when all hell breaks loose....
BURover
06-23-2009 05:57 PM
Disco Fuego
05-03-2009 09:26 PM
turpin
06-06-2007 11:24 AM
Randy Lover
09-24-2005 01:55 PM
parks
01-31-2005 01:21 PM
