need wires and advice...
have codes for a # of things, I'll start with 0305 misfire cylinder 5, misfire multiple cylinders
and a code for lambda sensor tv bank 1... about the wires i wanna know about magnecor prices, seems i cant get a price off their pricelist. heres what it says...
8 CYLINDER (US models only)
2004-1999 4.0, 4.6 V8 (except Discovery series I) 80242 87242 85242
1999 4.0 V8 Discovery series I 80142 87142 85142
1998-1995 4.0, 4.6 V8 80142 87142 85142
1996-1989 3.9, 4.2 V8 80196 87196 85196
1989-1980 3.5 V8 fuel injected engines 80190 87190 85190
1982-1976 3.5 V8 carbureted engines 80192 87192 85192
1975-1968 All V8
how pricey is a set? anyone had a super deal on them? the write up i got from the local dealer prices up their job @ around 900... Atlantic british has a set for eighty just wires, im looking to find if i can get magnecors' at about that price or better or am i barkin up the wrong tree?
1975-1968 All V8
1170 and some code that says low volts sensor circuit
0137
ive posted these before but only got a few replies back, spike suggests tune up, so im getting it together to do that, as my other post says ive had all O2 sensors replaced, computer wired back together (some loose connections found) codes were not present
after that. runs fine tho, no skippies or stutters, just comin up with codes and wanna cure them up.
0137
yes have had all of them replaced within 4months, first landrover did the driver side, then i got 2 from atlantic british for the other side, had the neighborhood mechanic do those. drove around due for inspection but knew i couldnt get it to pass with engine light on. then had computer rewired and codes ceased. now have codes that are persistently comin up, so i bought a scanner.
