need wires and advice...
Old Mar 27, 2009 | 07:24 PM
JBEGIN's Avatar
Default need wires and advice...
have codes for a # of things, I'll start with 0305 misfire cylinder 5, misfire multiple cylinders
and a code for lambda sensor tv bank 1... about the wires i wanna know about magnecor prices, seems i cant get a price off their pricelist. heres what it says...
8 CYLINDER (US models only)
2004-1999 4.0, 4.6 V8 (except Discovery series I) 80242 87242 85242
1999 4.0 V8 Discovery series I 80142 87142 85142
1998-1995 4.0, 4.6 V8 80142 87142 85142
1996-1989 3.9, 4.2 V8 80196 87196 85196
1989-1980 3.5 V8 fuel injected engines 80190 87190 85190
1982-1976 3.5 V8 carbureted engines 80192 87192 85192
1975-1968 All V8
how pricey is a set? anyone had a super deal on them? the write up i got from the local dealer prices up their job @ around 900... Atlantic british has a set for eighty just wires, im looking to find if i can get magnecors' at about that price or better or am i barkin up the wrong tree?
Old Mar 27, 2009 | 07:53 PM
You can get a set for about $95 from Apex Performance?, I think that is the company, I do not know their web address.
Old Mar 27, 2009 | 08:14 PM
brooksa's Avatar
I bought mine through Apex
www.apexperformance.net
Old Mar 27, 2009 | 08:46 PM
JBEGIN's Avatar
they say champion plugs go very well in disco 2's, im not really on a budget here, just looking to upgrade stuff. whats a good plug to run with magnecors?
Old Mar 27, 2009 | 08:48 PM
Any Iridium plug.
Old Mar 27, 2009 | 08:53 PM
JBEGIN's Avatar
any chance that tuning this up could solve the oxygen sensor codes im getting?
1170 and some code that says low volts sensor circuit
Old Mar 27, 2009 | 09:03 PM
JBEGIN's Avatar
0137
ive posted these before but only got a few replies back, spike suggests tune up, so im getting it together to do that, as my other post says ive had all O2 sensors replaced, computer wired back together (some loose connections found) codes were not present
after that. runs fine tho, no skippies or stutters, just comin up with codes and wanna cure them up.
Old Mar 27, 2009 | 09:05 PM
JBEGIN's Avatar
oh about magnecors what size? 8mm? 7mm?
Old Mar 27, 2009 | 09:06 PM
Start with the tune up.
You said that you DID replace the O2's?
Old Mar 27, 2009 | 09:12 PM
JBEGIN's Avatar
yes have had all of them replaced within 4months, first landrover did the driver side, then i got 2 from atlantic british for the other side, had the neighborhood mechanic do those. drove around due for inspection but knew i couldnt get it to pass with engine light on. then had computer rewired and codes ceased. now have codes that are persistently comin up, so i bought a scanner.
