New 01 disco owner.
Old Nov 16, 2020 | 09:06 PM
greisinb's Avatar
I hope that fixes your issues. I think there are only 2 grease fittings so it sounds like you got those. Kind of cool to hear about the center diff lock, is it accessible from the cab or is it just a lever on the outside?
Old Nov 16, 2020 | 09:09 PM
andrwplsn's Avatar
4wd High
only from outside will post a photo tomorrow when I get some daylight.
Old Nov 17, 2020 | 07:32 PM
andrwplsn's Avatar
4wd High
So to engage cld would what way would you turn the shaft on the transfer case? Also should I get a light on the dash when its engaged?
Old Nov 17, 2020 | 07:41 PM
Extinct's Avatar
Originally Posted by andrwplsn
Finally changed out my 02 sensors. I did all 4 with bosch since I was under there. Sealed my airbox lid to the maf with some rtv and greased my front driveshaft. Do the serviceable front driveshafts only have 2 grease points? Thats all I could find while under there. I also found the at one point in this discos life some one installed a pull/push style lever for the center diff lock that sits along the frame on the passenger side. They also installed a white light under the rear bumper shining straight down wired in with the rear fogs. Odd.
There should be 5 grease points, one on the front u joint, one on the slip joint, two on the u-joints at the cardan joint, and one buried deep in the cardan joint. The last one is not accessible with the driveshaft in the truck, you need to remove the shaft to grease it. Good idea to do it at each oil change. Requires a grease injection style needle to lubricate.
Old Nov 17, 2020 | 07:55 PM
andrwplsn's Avatar
4wd High
I only found the one on the front u joint and the one for the slip joint. I'll have to take it off, clean and inspect.
Old Nov 18, 2020 | 07:03 AM
Extinct's Avatar
You don't have a servicable shaft then. Not all are. Eventually the u joints in the double cardan joint will wear out. It was a pretty common failure for folks to keep driving them after the u-joints were worn to the point the driveshaft flys off going down the road, it almost always destroys the transmission and sometimes the transfer case when that happens. The driveshaft will start chirping at low speed when it is about to go, serviceable shafts are not very expensive, you should probably put it on your to do list.
Old Nov 19, 2020 | 12:42 PM
andrwplsn's Avatar
4wd High
Anyone have advice in this question?
Thanks for the info. will add to the list!
escott16
Sep 9, 2020 10:23 PM
Sam Margulis
Jul 28, 2019 02:28 AM
ls1morethanyou
Build Threads
107
Dec 29, 2017 07:03 AM
LR03NJ
Dec 4, 2017 12:47 PM
maxman
May 30, 2011 11:13 PM
