New 02 Sensors and now a ton of error codes...
Old Oct 29, 2009 | 07:18 PM
audioclay's Avatar
Angry New 02 Sensors and now a ton of error codes...
Just replaced the front and rear O2 sensors and now I'm getting the following error codes:
P0159 - Bank 2 Sensor 2
P0150 - Malfunction Bank 2 Sensor 1
P1174 - Fuel Air Metering Manufacturer Control
P0174 - Bank 2 System 2 Lean
Not sure what the deal is. 02's swapped out easy enough. I covevered up the melted split loom on the leads. Made sure nothing was melted (on the wires) and cleaned them with contact cleaner and reassembled.
Started it up, let it come up to temperature and ran it down the road for 100 miles and it ran great then almost as soon as I turned the corner to the house, the CEL came on and spit out these codes.
I doubled checked everything and it looks 5x5 disconnected and reseated the the 02 sensors and reset the codes. It's off for now, but I expect it to light up again tomorrow.
Any idea? Need a young priest and an old priest?
Old Oct 29, 2009 | 07:31 PM
lipadj46's Avatar
Where did you get the sensors from? Are they the universal kind or the plug and play? Also are you sure about P0159? I can't find it. Also recheck the definition of P1174 think that is another lean code.
Old Oct 29, 2009 | 07:45 PM
Did you put them in the correct spots?
If I remember right they are location specific but I cannot confirm this.
Old Oct 29, 2009 | 07:48 PM
audioclay's Avatar
They are location specific for front and rear. Can't mess them up. The connector is different. I got them from Atlantic British
Old Oct 29, 2009 | 08:49 PM
lipadj46's Avatar
I've gotten 2 bad O2 sensors from AB this year. Get a good scanner and check out the actual voltages.
ArlowCT
Aug 5, 2015 07:00 AM
y2motoskier
Apr 28, 2012 02:45 PM
y2motoskier
Apr 28, 2012 02:31 PM
wildthing
May 22, 2010 02:59 PM
sloppyjoe
Dec 26, 2008 03:11 PM
