New brakes and rotors what do you think?
Old May 25, 2009 | 09:28 PM
aublec22's Avatar
Default New brakes and rotors what do you think?
Does any one have a suggestion for pads and rotors? RoversNorth has a pro line set for like $250. Are there others to look at or should I go with a land rover genuine part?
Since I am doing all the breaks is there anything special I should do? Any cleaning or fluids to add or any bleeding?? Any accesories I might want to think about?
__________________
The White Rhino
Old May 25, 2009 | 09:38 PM
aublec22's Avatar
And man o man atlantic british has tons of different options and kits and what not...
Old May 25, 2009 | 09:49 PM
Go with the kits from Atlantic British, just buy the best that you can afford.
As for what else to do while you are doing the brakes, flush the brake fluid, this needs to be done every 2 years.
Buy a quart of DOT 4 brake fluid, any fluid will do, full synthetic is best.
Old May 25, 2009 | 09:57 PM
aublec22's Avatar
sweet thanks. but does more expensive mean better?
Old May 25, 2009 | 10:01 PM
That depends, if it is OEM then you are paying for the name, if it is aftermarket then yes.
As a general consenses EBC makes some of the best brakes on the market.
Old May 25, 2009 | 10:07 PM
aublec22's Avatar
The ebc could be cool but i am not sure which to buy. I off road pretty heavy most of the year and the rest is an even split between hwy and town driving
Old May 25, 2009 | 10:09 PM
If money was no problem then I would buy these.
http://roverparts.com/Parts/9542EBC.cfm
If I were needing new pads and rotors but was on a budget then I would buy these.
http://roverparts.com/Parts/9542F.cfm
If I were just replacing the pads then either the EBC pads or the Lockheed pads.
Old May 25, 2009 | 10:17 PM
aublec22's Avatar
Yeah i like the description on the ebc with the dimples and what not. But a few of the pieces are on order at AB and I have been waiting almost a month for my purge flow valve... If I spent over $550 on brakes i would want to have to wait for them for x amount of weeks.
I am doing all four rotors and pads b/c I am finally eliminating my # amigos. How long are the ebc rotors supposed to last?
Old May 25, 2009 | 11:09 PM
bangkuaidiscovery04's Avatar
I'm looking at the doing the same exact thing. My brakes squeak so bad I think I wake the whole neighborhood every time I stop! Thinking long-term is the EBC or Ferodo a better buy? I'm thinking quality over quantity.
Old May 26, 2009 | 08:16 AM
I have never had a problem rodering something from AB and it not coming in.
If they have it in stock then it will ship out that same day if it is ordered before 4pm EST.
