New from Chicago with an engine noise
Old Jan 26, 2020 | 05:39 PM
mattdevine2's Avatar
Default New from Chicago with an engine noise
Hi, I was wondering if anybody could help me to diagnose an engine noise in my rover. I bought this rover a few weeks ago and have had this issue ever since I bought it. The engine likes to make a “knocking” noise when the engine has been running for over 30 minutes. I’ll attach a video for context. I drained the oil (there was only 2 quarts and has some sparkles in it...) and put in 6 quarts of Rotella 15w40. The noise has been reduced but it is still there. Thanks
heres the vid;
2000 Land Rover Discovery 2 130,900 miles
Old Jan 26, 2020 | 06:17 PM
Could be an exhaust leak hard to tell on the video. Could also be a lifter, liner, rocker etc. Do a little listening with a mechanic stethoscope to locate the area the noise is coming from
Old Jan 27, 2020 | 04:17 AM
JUKE179r's Avatar
Welcome to the forum.
Old Jan 27, 2020 | 08:10 AM
XRAD's Avatar
lifters/push rod tap. But you also have to get under the car and listen to bottom end as well. Might want to check your real time oil pressure.....given that you only drained out 2 quarts, you may have some major bearing damage......
Old May 11, 2020 | 09:54 PM
Frank4's Avatar
Replied to wrong thread. Had to delete.
01d2Jeff
ROAMING WITH FRIENDS
Feb 5, 2012 09:59 AM
A5scott
Sep 7, 2011 08:15 PM
ALEXAN
Aug 28, 2009 09:47 PM
der_ingenieur
Jul 5, 2009 07:16 AM
