New codes stored P1414 & P1415 (also P1412 & P1415)
Old May 18, 2018 | 03:33 PM
Richard Gallant's Avatar
Check both the lines connected to this - mine is an 04 for your canister might look different
this is on the bottom of the SAI pump make sure it is on there good
there is one of these on each side check both the small hose and larger hose of leaks
this is the left you need to check both those little hoses in the background as well
Also in the 1st image check the routing of the hoses make sure the right hose is on the right connector
Old May 19, 2018 | 11:21 AM
DiscoJuiz3's Avatar
7th Gear
Thank you so much for these pictures! I will check them today! Should I be checking them while the car is on? <—— I know silly question.
Old May 19, 2018 | 11:46 AM
DiscoJuiz3's Avatar
7th Gear
I think I found it ! It was that hose in the middle. Do you think a zip tie would be safe to put here ? Or will it melt?
It’s the hose between the hose that has a red Tip. Sorry I’m on my cell and can’t upload the pic.
http://luxuryautosac.com/parts-cars/640x480/005302-engine.jpg
Old May 20, 2018 | 12:35 PM
If it is the hose I think it is that should have a hose clamp on it, it is ab ig hose right beside the one with red?
Old May 21, 2018 | 10:00 AM
DiscoJuiz3's Avatar
7th Gear
Ok, finally got to a computer today. It is the one in the middle in between the one with the clamp and the one with the red rubber.
Attached Thumbnails New codes stored P1414 &amp; P1415 (also P1412 &amp; P1415)-disconnected-hose.jpg
Old May 21, 2018 | 10:03 AM
Saturnine's Avatar
I put a zip on mine
Old May 21, 2018 | 02:58 PM
Hi forget about that one, I checked mine is zip tied too.
Old Jun 25, 2018 | 04:57 PM
Steveohouston's Avatar
6th Gear
Hello everyone,
I'm new here but recently found a solution that makes it so you can eliminate the secondary air injection and all it's components completely without a check engine light. We have done it on a 2003 and 2004 Discovery II now with no issues and there is also the possibility for some ECU tuning for someone a bit more adventurous. Please DM me for more details.
Thank you,
Steve
Old Jun 25, 2018 | 05:45 PM
Best4x4's Avatar
Why not just post it to the forum? Personally SAI is not hard to maintain/fix, and who doesn’t like it when their LR sounds like a small jet upon startup? LoL
Old Jun 25, 2018 | 05:50 PM
6th Gear
I didn't want to violate any of the forum rules about advertising is really the only reason. It's ECU tuning that eliminates the SAI error from flagging in the ECU. Basically we have full access to the ECU mapping and diagnostics so it's a matter of knowing which changes to make. The ECU is the same one we have used in other applications for years.
