New coolant leak on left side of block near the front
Old Jan 3, 2015 | 12:24 PM
bcolins's Avatar
Default New coolant leak on left side of block near the front
I have a very slow drip coming down the left side of the block. It appears to be about 1-2 inches back from the front surface of the block.
Anyone had this coolant leak before and know what it is?
Brian in Cedar Park
Old Jan 3, 2015 | 12:33 PM
zeroone's Avatar
Sounds like the TB heater is leaking. Is the top of the Rocker cover wet?
If that isn't it you could be looking at something more serious.
Old Jan 3, 2015 | 01:10 PM
bcolins's Avatar
I replaced that about a year ago,....but I'll check it. Thanks.
Old Jan 3, 2015 | 03:24 PM
zeroone's Avatar
Could be the valley pan gasket as well. I experienced a leak at both ends of the intake manifold.
Old Jan 3, 2015 | 09:56 PM
dnice's Avatar
Clean the area real good to try and identify. Everything listed above could still be a problem. Doing a radiator pressure test will tell you right away where the issue is.
humroot
Jul 22, 2019 06:33 PM
texdisco
Jul 6, 2015 08:34 PM
Blakesrover
Feb 21, 2013 01:43 AM
ngarover
Apr 13, 2012 06:40 PM
Wallyg
Feb 23, 2012 08:38 PM
