New coolant temp sensor (On intake manifold) problems
Hey gang,
I replaced my engine coolant temp sensor (the fellow on the intake manifold, MEK100160) because it was off by about 12 degrees centigrade. On my way to work, my temp gauge starts climbing so I pull over. Engine doesn't feel hot at all and lower rad hose is cold. I check with my IR gun and I see a healthy 83 degrees. I drive home with the gauge climbing up to the red, and I check again with the IR gun, 83 degrees. Hawkeye shows a staggering 130.
Is my new sensor bad? or have I done something wrong?
Thanks in advance
Thanks in advance
I've never actually replaced this particular coolant sensor, but I also know the torque spec from the RAVE manual is about 15 lb-ft, and if you torqued the hell out of it, it's quite possible to crack the porcelain insulator on a coolant sensor, which can result in incorrect readings.
Gromeo
08-24-2015 11:21 PM
