New coolant temp sensor (On intake manifold) problems
Old Sep 23, 2019 | 01:00 PM
Tristan Stumpf's Avatar
Default New coolant temp sensor (On intake manifold) problems
Hey gang,
I replaced my engine coolant temp sensor (the fellow on the intake manifold, MEK100160) because it was off by about 12 degrees centigrade. On my way to work, my temp gauge starts climbing so I pull over. Engine doesn't feel hot at all and lower rad hose is cold. I check with my IR gun and I see a healthy 83 degrees. I drive home with the gauge climbing up to the red, and I check again with the IR gun, 83 degrees. Hawkeye shows a staggering 130.
Is my new sensor bad? or have I done something wrong?
Thanks in advance
Old Sep 23, 2019 | 01:22 PM
Jason Feuerstein's Avatar
When you replaced the sensor, did you bleed the coolant system? Did you clean the connectors on the wiring harness?
It's certainly possible that the sensor is bad, but let's run through everything else before buying parts.
Old Sep 23, 2019 | 01:34 PM
I bled the system but likely not well enough at all, and I did not clean the wiring harness at all, just swappy swappy. I think its just a restrictive sensor right? so it could just be a bad connection?
Thanks
Old Sep 23, 2019 | 01:52 PM
Thanks
It's a resistive sensor, so you want as clean of a connection as you can get between the connectors or the resistance of the grime and such becomes part of the resistance of the sensor and throws things off.
I've never actually replaced this particular coolant sensor, but I also know the torque spec from the RAVE manual is about 15 lb-ft, and if you torqued the hell out of it, it's quite possible to crack the porcelain insulator on a coolant sensor, which can result in incorrect readings.
Old Sep 23, 2019 | 02:23 PM
I hope I didn't torque the hell out of it, but I might have. Getting a wrench on the damn thing was a pretty horrible task. Ill try cleaning the thing off tonight and see what happens.
Thanks
Old Sep 23, 2019 | 04:19 PM
Best4x4's Avatar
I’ve had cheap aftermarket ones report much higher temps vs OEM units.
back9sunday
Aug 8, 2016 10:43 AM
Gromeo
Aug 24, 2015 11:21 PM
Coyote
Jun 24, 2013 03:24 PM
nik
Jun 3, 2012 10:06 PM
willlane
Jan 4, 2008 09:05 AM
