New D2. First lengthy inspection after buying sight unseen
Old 04-13-2020 | 09:19 PM
Best4x4's Avatar
I used to run that 20/50w Valvoline oil in my 94 RRC until it got very hard to find, and then I found out about the 15/40 Rotella which I personally like better. It's not as thick as the 20/50w and it's SO much easier to find basically anywhere.
  #22
Old 04-14-2020 | 08:50 AM
NewToTheTwo's Avatar
Originally Posted by Extinct
Good oil, very expensive relative to the diesel oil, .
Both good points and I know I can get the Rotella at WallyWorld........I'll have to consider switching back
  #23
Old 04-14-2020 | 01:53 PM
Jason Feuerstein's Avatar
The factory radio is nothing special and I would bin it for something more modern. Make sure it has pre-amp outputs if you do.
Also great to see your engine has preserved the underside of the vehicle with a layer of oil. I think that's why my Disco is as rust-free as it is.
Like many on this forum, I use Rotella 15W-40, and you can't beat the price versus the level of detergents in it. Dump some Seafoam in when you change it.
The other thing I would do is take a wire wheel to that rust on the frame and then spray paint it with a rust converter immediately. I then spray the frame with Fluid Film every winter to protect it from road salt. It's really something you need to stay on top of.
Theshire4x4
ROAMING WITH FRIENDS
04-24-2019 12:01 PM
Theshire4x4
09-23-2018 12:00 PM
Theshire4x4
02-11-2018 04:07 AM
Daedrix
06-01-2016 10:13 AM
chasej318
09-21-2012 03:45 PM
Quick Reply: New D2. First lengthy inspection after buying sight unseen
