New Differentials w/lift kit
Old Mar 21, 2026 | 06:06 PM
Aj6543's Avatar
Default New Differentials w/lift kit
If you put a 2 inch lift kit on a D2,
do you need to change out the front and rear differentials to a 4.11 gear set?
Also, what are lockers, ARB air lockers?
Old Mar 21, 2026 | 10:37 PM
Harvlr's Avatar
You don't need to change your gearing because of a 2" lift. You might consider it if using tires over 32" diameter.
A locker locks the differential making it solid from one wheel to the other (or front axle to rear if talking about the Centre Diff), rather than having a differential between them. On our Disco's (which have a pretty good Traction Control), a locker is unnecessary until you're doing some pretty serious off roading.
Mike Castaneda
Feb 6, 2023 09:35 PM
Discogo
May 24, 2021 08:51 PM
scottz
Apr 24, 2019 09:31 PM
cobbcj7
Freelander
Oct 5, 2016 12:46 PM
Bostonc16
Jul 18, 2014 10:16 PM
