New to Disco
Old 06-07-2022, 03:45 PM
MattR's Avatar
Haha welcome, and yeah I am on the Discovery journey right now... hopefully we both get them back up and rolling asap!
  #22
MattR's Avatar
Cheers Walt, yeah all roads lead to the code reader right now... will get onto it!
  #23
Old 06-08-2022, 09:43 AM
greisinb's Avatar
Originally Posted by MattR
One quick question on the chassis ground for battery... where is it? I have tried to Google but cannot seem to find a single definitive answer.
Cheers, Matt
It should be directly behind the negative battery post about 6 inches or so. Here a picture, circled in green. It's on a post which provide several ground points. Also, just because the picture reminded me of it, check your bottle jack, over the years the fluid had completely run out of mine and I just happened to check it out of luck and found that it didn't work- best to know now before you might need it! I keep mine in the back storage cubby now so it can sit upright away from the heat (plus I've modified my battery box a little bit so it would no longer fit anyway).
  #24
Old 06-08-2022, 03:52 PM
MattR's Avatar
Awesome thanks so much for that - and the jack tip!
  #25
Old 06-14-2022, 10:56 PM
MattR's Avatar
Update: Early days, but I replaced the crank sensor yesterday and have not experienced any issues yet - though have only taken her for a couple of spins. Note: Out of all the guides I read about changing the sensor, not one mentioned what a PITA the harness would be... If anyone reads this it is best accessed from above, and you need to push it back towards the firewall to get it out of the bracket first before disconnecting. I would recommend attaching the sensor itself before trying to reconnect harness, and pushing sensor end of plug against the bracket when reconnecting as the cable wants to twist away the whole time (unless there is a way better method I missed in my reading!). Thanks again for all your help, Matt
  #26
Old 06-14-2022, 11:31 PM
andino's Avatar
I used some really long needle nose pliers when I did mine. Was able to reach the clasp on the plug end and just press it down to pull down. Reverse to put it back on but I couldn't get them to clip so I got it as close as I could then used my hands to press the ends together.
I used a pair like these:
  #27
Old 06-14-2022, 11:33 PM
MattR's Avatar
Yeah I wish I had something like that to hand... I tried with a few sets of pliers but nothing was able to get in that space. Had to take a few breaks to get myself zen during the process!
Theresonly1santi@gmail.com
02-23-2022 10:10 PM
Meldav32
05-06-2018 02:58 PM
pthork
01-26-2018 12:59 PM
bobmaucher
05-16-2012 09:09 PM
girouardrover
10-02-2011 09:06 PM
Quick Reply: New to Disco
