New Disco 2
Old Sep 6, 2020 | 09:52 AM
Andres Honold's Avatar
Default New Disco 2
Hey,
Just Bought a 2003 Land Rover Discovery 2 with 86,000 miles on it and am very excited. What do you recommend are the first things I should be
looking out for?
Old Sep 6, 2020 | 10:29 AM
timsvoice's Avatar
3rd Gear
Hey @Andres Honold ! Congrats. I also just picked up my first Disco II and posted a similar question here: https://landroverforums.com/forum/di...ngs-do-101932/
First thing I did was order an ultragauge to monitor temps.
Old Sep 6, 2020 | 11:35 AM
Dave03S's Avatar
Welcome!
I would recommend the first thing you do is spend more time reading the posts about what should be the first thing to do, there are many here!!
But seriously, there is a wealth of info here already posted... Your new Rover will take plenty of your time an attention, That starts right here by reading up on what you just did!!
Best of luck, and come back with questions after you are up to speed!
And hopefully you have some mechanical ability.
Old Sep 6, 2020 | 01:17 PM
Richard Gallant's Avatar
@Andres Honold Welcome
Start simple bluetooth ODB reader that plugs into the ODB port on your Disco, then Torque for Android or a similar app for Iphones and montor you actual engine temps. The dash gauge is functionally an Idiot light.
You have a steel sleeved aluminum engine and engine temps are very critical,overheating will warp heads and compromise head gaskets.
Beyond that fluid changes are usually the 1st thing I do, oil, transfer case, diffs. The transmission should be serviced to my way of thinking but if it shifts without issue I would leave it alone initially.
Check your drive shafts, for play the front one in particular does a lot of damage if it lets go
Old Sep 7, 2020 | 12:01 PM
Jason_B's Avatar
Welcome. Seems like pretty low miles, thats awesome.
1. Front drive-shat like a tom woods or British parts of Utah since the stock one isn't serviceable and can explode.
2. Scan guage/ ultra gauge to monitor temps. Should be in the 188-200 range. 215+ is danger zone. 230+ is scary.
3. 180 degree stat (pretty easy to change) but will take flushing / re-filling coolant system. Bleeding can be tricky.
3. Check / change fluids. Brake fluid, power steering, coolant and oil are all a 5 second check. Diff fluids, t-case, and transmission are a little more complicated.
4. Full "tune up": MAF, front o2 sensors, spark plugs, wires, coil packs
Benjamin Larrea Hernandez
Apr 6, 2020 02:25 PM
mattmynhier
Jun 2, 2013 10:58 AM
4x4ron
Jun 9, 2012 03:54 PM
preple
Feb 14, 2011 07:14 AM
l3x702
Apr 13, 2009 06:24 AM
