New disco II owner with a question
Old Oct 28, 2012 | 08:55 PM
mtrdrms's Avatar
Default New disco II owner with a question
Hey all. Just went back into rover world with the purchase of a clean 2000 discovery. I had a 97 a while back and always regreted selling it so here I am, drinking the cool-aid again. My question is this: I just replaced the gasket on the powersteering pump and that went well but now my serp belt is squealing. I thought I just spilled some junk on the belt so I replaced it but even the new one sings. The sound certainly seems to be coming from the pump and there was no squealing before this. So is this just a coincidence and my tensioner is bad (how do I test that?) or should I not have put atf in the power steering system?
Thanks in advance,
Andy
Old Oct 28, 2012 | 08:58 PM
Remove the belt, start the engine, is the noise gone?
Yes?
Shut off engine, turn each and every pulley by hand, feel for a gravely feeling or a hard to turn pulley.
Obviously power steering pump will be hard to turn by hand but tensioner pulleys will be easy as well as the water pump.
Old Oct 28, 2012 | 09:07 PM
mtrdrms's Avatar
Thanks spike. When I had the belt off to do the pump I check all pulleys and they were good. It seems the belt is slipping either around the crank pulley or ps pulley. How much tension should the belt have? The tensioner doesnt seems as strong as other vehicles I have owned.
Old Oct 28, 2012 | 09:11 PM
There should no no more than 1" of play.
So with the engine off press on the longest part of the belt and it should move less than 1".
Old Oct 28, 2012 | 09:19 PM
mtrdrms's Avatar
Great. So you don't think ATF is a problem?
Old Oct 28, 2012 | 09:29 PM
Nope, ATF is not a problem.
Old Oct 28, 2012 | 10:46 PM
bigcraigman's Avatar
I had no idea you could put ATF is a power steering system? I guess it's still fluid pressure but I thought that was just D1's. Please fill me in.
Old Oct 28, 2012 | 11:07 PM
Racer X's Avatar
You could be like mine was, and be missing the idler pulley between the A/C compressor and the PS pump.
Old Oct 29, 2012 | 12:27 AM
jfall's Avatar
Make sure you routed the belt correctly.
Check that the three 10mm pulley bolts are holding the pulley on snug.
Warning- over tightening those bolts snaps the casting on the pump ears.
Old Oct 29, 2012 | 12:31 AM
jfall's Avatar
NOT an ATF problem.
You can run ATF in the PS pump no problem.
If you put that seal in - and the seal is blocking the flow of power steering fluid - ie - you put the seal in wrong, then you may have higher turning resistance..
But, I bet that went OK and you can steer fine
You can check the tensioner - just try to untension it - should be rather hard to do .
IN this video - tension is taken off off the tensioner.
Run33
May 11, 2015 09:43 PM
kayak74
Jan 23, 2013 07:13 AM
zhirkhan
Jul 1, 2011 08:06 PM
upnorth rover
Oct 23, 2009 04:09 PM
tdiddy
Feb 11, 2006 02:21 AM
