New Disco Owner
Location: Charles Town, WV, originally from Central Valley, California
on
Greetings all. I just purchased a 2003 Disco II after owning a '56 and '72 Series Rover. I used information on this Board to check it out and the advice was great. I have a couple queries for the members, though; Can the same method to correct water in the tail lights be used on the front headlight unit?; and, where is the best place/source to get a spare remote key (only received one that worked and a blank). Any help and additional advice is greatly appreciated.
Regards, Art
Regards, Art
Yes you can drill holes in the light . I have them in mine
The think the best way to sort out another key fob is to buy one from a parts reaper that has the code with it. you have to have it programmed by someone that has the proper tool/ Computer . You will also need a key blank to get cut . I have a nanocom and it will do it , others will as well . Or you can take the quite costly approach of mine a new one altogether.
on
Run33
05-11-2015 09:43 PM
kayak74
01-23-2013 07:13 AM
MuddMouth
09-30-2010 10:30 PM
