The new drive shaft is in, but the vibration lingers.
Old Mar 17, 2011 | 09:06 PM
Snafu / Disco Fries's Avatar
Originally Posted by photocrimes
If you are getting the vibration in neutral I have a hard time believing its the drivetrain. Any chance the motor was rebuilt? How is the compression on the cylinders? If you have a cylinder that is losing compression, or maybe a weak injector, it may cause a harmonic vibration that only shows up in certain ranges. Vibrations are tough as just about any spinning item can cause it.
I'll have to borrow everything to check the compression. Wanted to do that anyway at some point. I think it is something engine though. Not sure about low compression somewhere though... wouldn't that throw a CEL if it was running rough enough to cause a vibration?
Old Mar 22, 2011 | 06:37 PM
cksbiker43's Avatar
I have the same vibration issues with my '00 DII. I've replaced the rotoflex & front drive shaft. Vibration start at 70 mph. what are the possibilities it's the transmission or transfer case?
Old Mar 22, 2011 | 07:16 PM
grandkodiak's Avatar
is it the same vibration while in neutral as in sitting in idle parked?
if not and its only at speed...how long ago did you have your wheels balanced if not any other above mentioned potential cause? check for dirt etc. built up on the inside etc.
low comression wont through a code unless its enough to cause a missfire usually... but it will definatly cause a vibration in the motor reguardless if you are sitting still or moving in gear... but it would show up most likely at a certain rpm in every gear, not just during a certain speed.
if its in a particular speed range its driveline or tires, or alittle both.
Old Mar 22, 2011 | 09:51 PM
It seems to be a little roughness in neutral revving the engine. The vibration is in every gear more over the 3500RPM range. There is a vibration lately over 75ish, but I do think that is more tire/shock related.
Old Mar 22, 2011 | 10:22 PM
bosshogt's Avatar
I just got rid of my RotoFlex. Converted to a grease-able GBR(Great Basin Rovers) rear driveshaft. Its a little costly b/c you have to convert the rear pinion flange to 4 bolt. But it got rid of my 35mph and 55mph slight vibrations. Everything rolls smooth now.
I'm not saying this is your problem, but it fixed my ever so slight vibration. Also I have a 2" OME lift and have heard DO NOT have a Rotoflex with any body lift.
GBR serviceable rear drive shaft on eBay $160 shipped
GBR 4 bolt pinion flange with oil seal $100 from Great Basin.(new).
Not a bad deal for now a fully grease-able front & rear drive train.
Old Mar 23, 2011 | 11:04 AM
Originally Posted by jeffh
Replace the Roto-Flex at the rear. you will be amazed. I know I was. and it was the last thing I would have looked for. and that only takes 10 minutes.
Where did you get yours from? Been looking around a bit.
Old Mar 24, 2011 | 08:01 AM
jeffh's Avatar
Snafu,
I got the roto-flex from a place in FLorida.. off of Ebay. sealed in LR package et al. they are a LR dealership in the Miami area. I know I have the paper work I will drum it up and pass it on. But it was off of EBAY.
Old Mar 24, 2011 | 05:42 PM
bosshogt's Avatar
This is the place. Miami British. They have great prices and free shipping on some items.
I buy a lot of stuff from there.
Miami British items - Get great deals on Lamps, Interior items on eBay Stores!
Old Mar 24, 2011 | 08:16 PM
Thank you both! Will check out those shops.
DiscoJon
Jul 14, 2019 01:51 PM
glassman66
Feb 12, 2012 10:21 AM
Rover Nick
Apr 19, 2011 08:16 PM
andrewmcoffin
Nov 21, 2010 08:18 PM
brooksa
Jun 6, 2008 09:34 PM
