New ECU/BCU/Cluster, but my car doesn't have DMTL/leak detection? Can I clone my ECU?
Old May 27, 2021 | 01:16 AM
gammacurve's Avatar
Unhappy New ECU/BCU/Cluster, but my car doesn't have DMTL/leak detection? Can I clone my ECU?
Picked up my first Land Rover about 2 weeks ago and chased down an unresponsive upstream o2 through the harness all the way to the ECU.
ECU was bad, found a parts car locally for extremely cheap and moved the engine harness, ECU, BCU, and cluster over. Car started right up but keeps throwing P1451 (EVAP circuit) , P0447 (EVAP circuit open), P1117 (coolant temp sensor that my MY2000 doesn't have).
I spent all day trying to trace the problem and I finally found out that my MY2000 does not have the DMTL leak detection so the donor car's ECU is having a fit because it's looking for something that isn't there.
I have access to a T4 Testbook I believe, can I duplicate my old ECU with it? Or sync my new ECU to my old BCU and cluster and it will adapt? Not sure how it works as I come from the BMW side of things where I can fullread most early OBD2 ECUs through free software.
Thanks a bunch!
Old Aug 19, 2021 | 11:23 PM
gammacurve's Avatar
bump!
Old Aug 20, 2021 | 06:50 PM
Extinct's Avatar
Yeah, just flash your new ECU with the old program. My Rover guy had the OEM system also and he did one on a replacement ECU for me also.
clint70
Nov 6, 2019 05:43 AM
emt2976
Sep 4, 2014 05:49 PM
willys_49
Nov 10, 2012 07:42 AM
JRdisco1
Aug 25, 2005 03:07 PM
