New front propshaft - heavy duty neccessary?
New front prop shaft time.
I got my 2003 D2 with no previous owner information. It has Terrafirma shocks. The springs are grey but I'm unsure of the lift. Measurement is 35.5 inches from the ground to the fender arch. I have 245 x 75 x 16inch wheels.
My question is do I really need a Tom Woods drive shaft with what I think is a small lift.
I'd like to get a service-able prop shaft.
This is a weekend car that sees about 5,000 miles a year and only goes off road on trials a couple of times a year. Uwharrie State Park in North Carolina.
I wanted to get the less expensive prop shaft from Lucky8 but should I go ahead and order the Tom Woods?
Thanks,
Thanks,
Thanks,
Thanks,
no you don’t need a tom woods
just get one that is serviceable with grease
cvhyatt (02-19-2020)
my Lucky8 front prop shaft just failed on me the other day. fortunately i heard the u-joints clicking before it locked up and exploded.
i run a two (2) inch lift and 275-65-18 tires. i put about about 60,000 miles or so on the Lucky8 prop shaft over the last several years. i drive this truck everyday and have taken it through the Rockies and Smokies both on and off road.
you may want to all Lucky8 about which front driveshaft they recommend for your application. i don't think they recommend that driveshaft for any lift two (2) inches or higher.
J-redrover
08-22-2011 07:50 AM
