New front shaft
Old Jan 20, 2013 | 05:17 PM
roverich's Avatar
Default New front shaft
so i am getting ready to buy a new front drive shaft and have been doing research , thinking about getting one from Great basin . They look like they are decent . Also , should i get rid of the rotoflex coupling and get one for the rear while i am at it ? Next major thing will be lockers and HD axles currently have 2 inch OME lift ...
Old Jan 20, 2013 | 05:35 PM
ZGPhoto's Avatar
GBR has a great prop shaft, their stuff is top notch. Inspect the rotoflex before you decide to buy a new one. Have you installed a center diff lock kit of some sort? If not that's very important before you get lockers.
Old Jan 20, 2013 | 05:53 PM
jeffh's Avatar
I have the Heavy duty GBR Front prop shaft. I love it. Bill and his shop are top notch. The question on the roto flex is one that has many people split. I have chosen so far to keep mine, the reason being, is that I keep a spare in my spare parts kit when traveling. Should I get in spot that I torch one I can replace without cause for concern. If you go to the solid flange and something goes wrong you are stuck. My 2 cents.
jnance50
Feb 18, 2010 09:19 AM
Ruffin' It
Jun 2, 2009 11:13 AM
treho54
Oct 19, 2008 04:28 PM
treho54
Oct 7, 2008 10:55 AM
Berryman
May 6, 2008 01:18 PM
