New HG Day!
Old Jan 28, 2017 | 08:51 AM
robert.juric's Avatar
Default New HG Day!
Happy day!!
So which side is the block side of these head gaskets? One side has a red stripe and more of the metal showing. Any final block cleaning advice before I install them?
Old Jan 28, 2017 | 08:58 AM
abran's Avatar
Look closely, the gasket should say top on it.
Old Jan 28, 2017 | 09:10 AM
KingKoopa's Avatar
my gaskets did not have "top" anywhere on them. research revealed that the side with the red lines and extra meta goes up.
Old Jan 28, 2017 | 09:13 AM
I could be missing it on these new ones. I dug out the old ones and I was able to find top stamped on the side with the red stripe and more metal.
Old Jan 28, 2017 | 03:16 PM
Well I made some progress! Heads are finally back on and torqued down. I hope I did that correct. I started to reinstall the rocker arm assembly but the bolts to secure it won't thread in. I think there is gunk left over from the hot dip the machine shop did. Is there any secret tip to get that crud out? I really wish I had caught it before I reinstalled the heads but now I will have to deal with it.
Old Jan 28, 2017 | 04:26 PM
LR03NJ's Avatar
Try getting a nipple brush. If you need sone heavy duty brush, get the ones to clean a tubing. But that might be to big for the hole unless you glide a tap just to remove the gunk.
Old Jan 28, 2017 | 04:36 PM
KingKoopa's Avatar
You should be able to get most of it with compressed air. After that, lube a bolt up and chase each thread.
Old Jan 28, 2017 | 07:52 PM
Jeff Blake's Avatar
Fill the hole with carb cleaner, swish it around with these
https://www.amazon.com/Performance-T...gine+brush+kit
and then shop towels and q-tip's to pull all the muck out
Old Jan 28, 2017 | 07:55 PM
LR03NJ's Avatar
Right! I remember using Q-tips. LOL
Old Jan 29, 2017 | 04:13 PM
Thanks guys! Great advice!
