New knock on the block - need help with diagnosis
#21
FWIW, I had/have a slipped sleeve on #4 cylinder. I did nothing about until I had to do my head gaskets. I got the sleeve back down via dry ice in the cylinder and a steel plate pressing it back to flush with the top of the block. That was 45,000 miles ago. My ticking sounds like yours, but I do not know if it is the sleeve or something else. Looking forward to hearing what you find.
PS- My engine has had a ticking sound for almost 95,000 miles.
#22
Question: how much did your liner slip? Is it something visible or more like in hundreds or thousands of an inch?
#24
Lol, sounds like the I have some time before it explodes. I'm trying to do the oil pressure check, but the weather has turned nasty and it's been raining all week. If the oil pressure is ok, I'll drop the pan an take a gander.
#25
So it sounds like i should be able to measure this fairly easily or maybe even see - least that will be an easy diagnosis.
#29
Finally, I got to doing some of the checks before I pull the oil pan.
Oil pressure goes from 30 psi at idle to a steady 40psi - rave says it should be 50psi at 2000 rpm, but mine just stays at 40, maybe 42psi if I rev it up past 2000 rpm - I'm not sure whether this is concerning or not (maybe the pressure relief spring has gone bad?).
Also, I pulled the sparkplugs, which all looked fine, and scoped the bores - nothing out of the ordinary there.
On another note, here are a couple of pics from inside the bore. The liner seems to be resting flush on a ledge in the block, so I'm not really sure how would it slip down...
#30
What weight oil are you running? If it runs a steady 30 psi at idle when hot that is more than enough. Most will not clear 45 psi unless you really get the engine spinning to 4000 ish.
The slipped liner thing has long been a mystery. They slip up believe it or not and that is what causes the tapping. If was tapping and you have the engine out you may want to consider pinning the cylinders.
