new land rover owner
Old 04-18-2017 | 10:48 PM
djfoxxy9's Avatar
Default new land rover owner
Okay when does the second fan come on in a 03 discovery 4.6.
Old 04-19-2017 | 05:21 AM
Luckyjayb's Avatar
if you are talking about the condenser fan (the one u see looking through the grille) here is the spec sheet for it and the viscous clutch flan.
Old 04-19-2017 | 09:46 AM
SensiRider's Avatar
Doesn't the fan also turn on anytime the A/C is switched to MAX?
Old 04-19-2017 | 11:06 AM
The Deputy's Avatar
If you leave in the salt belt, reach in there with a long screwdriver and see if you can turn the blade manually. Both mine were froze up (01 +03).
Brian.
Old 04-19-2017 | 11:58 AM
Luckyjayb's Avatar
nope. Only when those temps/speeds are met but take the advice a with your truck off see if you can turn it with a screwdriver. It might be froze up and if so there is a thread about a cheaper replacement motor somewhere on this forum
Uriah Christian
04-27-2017 12:30 PM
Run33
05-11-2015 09:43 PM
bagocheetohs
03-28-2011 07:38 PM
gereth0316
12-13-2007 12:33 PM
MiniManiac
03-31-2005 01:28 PM
Quick Reply: new land rover owner
