new owner
Old Jun 11, 2007 | 10:22 AM
inabinn's Avatar
Default new owner
hey guys this is my first post on this website and i have a few questions about my new truck. i just got an 02 discovery se with about 70,000 miles on it. so far i love it to death but there are some things that are nerv racking to me as a new owner. maybe some of this is normal but i just want to make sure.
1. every time i lift off of the accelerator i can feel this clunking feeling. can you tell me what this might be or is it normal for these vehicles. this is my 1st 4 wheel drive vehicle and i dont know if it has anything to do with that or not but anyways ...
2. while i was driving back from the dealer my father and i noticed a very slight whine comming from somewhere. could this be a driveline issue that is related to the clunk ?
3. are there any ways to get better gas mileage. my last truck was a ford sporttrac with lift, tires, roofrack .... pretty much everything to kill the mileage so im used to emptying my wallet at the gas stations but with the disco having a larger tank and higher octane fuel im looking for anything to help.
any replies would be great !!
[/align]
Old Jun 11, 2007 | 04:22 PM
98roverguy's Avatar
Default RE: new owner
1 AND 2 - At 70K your ready to replace your U-joints. Unless you know for sure it has already been done, replace them regardless and that may fix your whine and clunk noise. Do this asap cause if you don't you could turn your transmission into a potato masher.
3. Look into Magnacor wires and Bosch Platinum plugs. Check air filter. Being a disco not much you can do. Figure out excatly what sort of gas mileage your getting and get back to us.
Old Jun 12, 2007 | 08:43 AM
inabinn's Avatar
how much does it cost to replace the u joints ? as far as milage i got about 350 miles out of my last tank of gas.
[/align]
Old Jun 12, 2007 | 10:18 AM
johnnybob06's Avatar
If you got 350 miles outta your last tank, I would be bowing down to your truck and thanking her!
I only get around 270-280 per tank! :S
The wires and plugs that were suggested are a great start!
But one thing that is a constant mention is to keep her maintained! Always run premium gas, and love her to death!
John-Robert
Old Jun 12, 2007 | 11:14 AM
Both the klunk and the t/case whne are normal.
I would suggest you plan on doing a fairly major servious on this truck, especially if it didn't have the 60K done.
I you want, I can send you an extensive list of stuff to do, that if you are at all mechanical, you can do on your driveway.
Mike
Old Jun 12, 2007 | 04:09 PM
inabinn's Avatar
im glad to hear that the klunk and whine are normal. the dealer that sold the vehicle said that it underwent a full maintenance service right before i bought it at 74k miles.should i be alright with this or do i need to look into servicing/replacing parts? i also want to add that ifound reccords that the 60k service was skipped and done right before the purchase.
johnnybob , those were all highway miles so im guessing i'll be seeing the same numbers as you next week
[/align]
Old Jun 12, 2007 | 04:13 PM
Well it is safe to say the 60K wasn't done, your dealer wouldnt pay for that big service. Are you able to do some work if you are told how to do it?
Mike
Old Jun 12, 2007 | 07:33 PM
inabinn's Avatar
yeah i can do some very minor things if told how to. i dont have any real experience turning a wrench but im sure i can do it if it comes down to it. do you think i can get that list from you ?
[/align]
Old Jun 13, 2007 | 09:10 AM
So here is a list I put together a long time ago, it is very extensive and when all done your truck will be ready for pretty much anything. I fyou have someone who can help you, this could save you about $600 in labor alone.
This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transsmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both od the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
Run33
May 11, 2015 09:43 PM
Chief
Sep 23, 2008 02:36 PM
jwinck
Sep 19, 2008 12:37 AM
desh72
May 5, 2007 12:03 AM
ctcnewton
Feb 18, 2006 12:32 AM
