New plugs, new wires, new coils & and still misfiring
Old Mar 6, 2017 | 11:04 AM
  #21
Luckyjayb's Avatar
Originally Posted by mollusc
Any decent auto parts store will have the Dorman purge valve, part number 911-800, in stock. It's a straight swap for the OEM one for about twenty bucks and no waiting for shipping. Try a local independent store first before you try a chain store because it's probably cheaper.
or call Hyundai and get it from them. I'm. It sure if the orientation of it has anything to do with it but I know Friday night disco was having trouble with tricky dicky with one
Old Mar 6, 2017 | 06:08 PM
  #22
jamestfl's Avatar
x2 on the hyundai/Dorman purge valve. Been running one for about 2 years, no issues.
Old Mar 7, 2017 | 01:10 PM
  #23
Friday Night Disco's Avatar
Clean your gas cap and spout with a scotch-brute pad, clear the codes and drive 30 miles and report back
Old Mar 8, 2017 | 12:34 PM
  #24
back9sunday's Avatar
I'll definitely give that a try.
I did order the BOSCH sensors from Atlantic British and installed them, which I think was a sound install. Heard the click when the connectors were engaged and everything. Purge valve for sure, but my main focus is the misfiring, especially misfiring without throwing codes. When I first started having this misfiring problem, my codes were your expected p0305 (cyl 5), but along with that I got p0132, and p1319. I was led to believe that was an O2 sensor inactivity/voltage fault and so replaced all of them, along with new coils, plugs, and wires a week prior to that. Yet I'm still getting my misfires.
Old Mar 8, 2017 | 12:55 PM
  #25
Luckyjayb's Avatar
what kind of plugs and wires do you have?
Old Mar 8, 2017 | 12:56 PM
  #26
mollusc's Avatar
I went through a lot of the same thing, changing the upstream O2s, the plugs, coils, and wires but still having misfires. Fixed it by changing the MAS air flow sensor (go for the Bosch one, not the cheap one which won't fix anything) and the purge valve. All misfires and codes have been gone for about 500 miles now, and I passed inspection yesterday.
Old Mar 8, 2017 | 04:37 PM
  #27
that is a novel idea. I have a spare sitting around tht I acquired at a parts lot, but I'm hesitant to throw that in. It looks to be in good condition.
and I replaced my plugs with NGK plugs and 8mm Magnecor wires.
Old Mar 15, 2017 | 11:00 PM
  #28
So switched out the MAF sensor, and the trucks performance has improved. I say improved in that it seems to be breathing better and pulling harder.
However the misfires codes are still present (p0300, p0302), rough idle and a fair amount of ticking at startup and under accel.
I've read up that spark plugs for our Disco2's should be gapped to 0.38 - 0.41" of gap? I don't believe I checked my plugs before I installed them. And a mis-gapped plug could be a cause for misfires. Also, the aforementioned vacuum leaks could be a possible cause.
I should have given some background to this post a while ago, so apologies for that:
The misfiring started after an outing where I dipped the front end up to the top of the wheel arches in cold river water. I noticed on the ride back to civilization that my engine had developed a misfire on Cyl 5 (hence the p0305 code, which has gone away (???)) So the engine was misfiring before the coil pack, plug, and plug wire replacement, as well as MAF & Purge valve. My plugs are NGK, wires Magnecor 8mm, and coil packs Bosch.
Old Mar 16, 2017 | 12:39 AM
  #29
chubbs878's Avatar
I would think that the new parts did you some good as the misfire is no longer on the cylinder that was originally giving you problems. That counts for something in the proper direction. As for the misfire on a different cylinder it could be anything from a bad connection of that lead on either end to a totally faulty wire. Most spark plugs are supposedly gapped correctly & not to be tampered with but I check them regardless & found 1 or 2 to be way off last time. Have you tried observing the engine idling in the dark? If you hear ticking sounds it may be possible to see an arc jumping in the dark. Check your spark plug, then swap it with its neighbor & switch 2 of the leads if you can get your hands back there; if code follows cylinder you found your problem. If not, rule it out & move on. Also see to it all 4 bolts are secured on the coil pack mounting bracket. It won't cost anything starting here. If you suspect a vac' leak, that is also free & easy, and you should investigate anyway. Hit the intake manifold with combustible spray or vapor; O-rings on the fuel injectors tend to harden & cause problems with vac leaks, the plastic pipes & fittings crack, gaskets get old & brittle. If the top end hasn't been refreshed there is no telling... and you can't trust replacement parts just because they are new in a box. I have been getting more & more defunct items that have needed to be replaced under warranty multiple times so it just adds to the dilemma especially when it comes down to sensors & electrical.
Old Mar 18, 2017 | 09:52 AM
  #30
thanks for all the input! I'll try out switching soak plus today and possibly the wire connection on the pack. I wouldve given this a shot sooner but I'm been working as emergency crew at the Oroville Dam. And that is all consuming lol!
