New Problem 03 Discovery
Old Oct 25, 2008 | 01:01 PM
jmrivera's Avatar
Default RE: New Problem 03 Discovery
Damn, but that's a rover part - pricey!
Perhaps you can check the voltages shown in the picture... At least then you'll rule it out if it isn;t the problem and save a couple hundred!
Jonathan
Old Oct 25, 2008 | 05:41 PM
DeepBlueWater's Avatar
I too have an 03 and have experienced the same problem.
I've had the same blinking lights, code and inability to shift into gear. I'm not too concerned with the occurrence.
I simply turned the engine off and did a restart. The blinking lights extinguished, I cleared the code with my OBD2 and the vehicle has shifted properly ever since. I've driven probably 40K since then.
Considering the hundreds of elements that become active at start-up it seems logical that an occasional error will occur.
MWmG
Old Oct 25, 2008 | 06:08 PM
I have not heard of this part going bad but that doesnt mean that it cant happen.
I do not know how you would test it.
Old Oct 26, 2008 | 10:08 PM
tex599's Avatar
Does anybody have a part number for it? AB just has their part #, need the actual land rover part # to search.
thanks
Old Oct 26, 2008 | 10:30 PM
jmrivera's Avatar
This is what I found:
UHB100190 Gear position switch (AKA neutral safety switch) $198.00 @ British Pacific
I also found this - I know it's for an '01, but it may help!
http://en.allexperts.com/q/Land-Rove...Disco-II-M.htm
Jonathan
Old Oct 27, 2008 | 11:42 AM
tex599's Avatar
Thanks, I spoke to the guys at Roverland and they have them used for $125.00. Not sure if I should buy this used or not.
jnolan
Jan 26, 2015 06:25 AM
Scope
Apr 12, 2013 10:36 AM
tskeltonPGA
Jan 16, 2008 07:21 PM
