NEW problem with timing
Ok now my dad seems to think that all that is wrong with my discovery is that my timing is off bc i put in new spark plugs. It idles real rough to a point it shakes the car but only at idle, when i take off everything is fine. How do i get my timing reset and how much are we talking here?
What do you mean wrong heat range? As in maybe my the plugs i bought were the wrong ones? I got bosh platinums and spaced them to .33 like advanced auto parts said to. Am i stupid for listening to advanced auto parts?
No, you are not stupid, I just listed out some possibilitys as to what might be causing your problem.
Start you engine and one at a time, pull a spark plug wire and see how it effects the idle. If there is a bad plug, when you plull that particular one there will be no difference in the idle. The other possibility is that when you first removed the plug wires to replace the plugs, you may have damaged the plug wire.
Mike
Mike
Martin Rodriguez
Feb 25, 2014 08:55 PM
AffordableEngine.com
Nov 19, 2011 05:17 PM
mandythelandy
Defender
Dec 26, 2008 04:33 AM
