new rear shock mount location?
Old Apr 4, 2014 | 11:01 AM
  #31
Dane!'s Avatar
Double triangulated 4 link front, that's the first time I've seen that on a disco. I wish I could run the numbers on that, see what the stats are like.
ZG, I was thinking the exact same thing. Looks like the driveshaft would want to bind quite a bit from this angle.
Old Apr 4, 2014 | 11:02 AM
  #32
dusty1's Avatar
well, that clears my confusion with the contact addy ...rovertym.******@*****
Old Apr 4, 2014 | 11:03 AM
  #33
Dane!'s Avatar
Custom radius arms fully articulating 16" coil overs.
EDIT: Found a D2 TD5 wit custom castors on 33's and 11'' shocks (not sure if that number is right, just got it from the website)
Old Apr 4, 2014 | 11:09 AM
  #34
ZGPhoto's Avatar
I believe if you're able to run ballistic joints on the D2 front radius arms you'll gain a bit of flex, I know Mike Widener has that on his d2 with a 4 link rear.
Old Apr 4, 2014 | 11:15 AM
  #35
dusty1's Avatar
I think something like that, be the plan......super simple.
the fugliest thing I have seen in the research is this
Old Apr 4, 2014 | 11:16 AM
  #36
Dane!'s Avatar
I wanted to run a heim joint with a misalignment spacer as the upper. That would give you more flex up on the upper and less bind on the lower polys. But I guess it rides terrible, and heims don't last long.
I wouldn't run that lol. It lets your pinion angle jump up and down and its limited by your shock bushings and driveshaft binding
Old Apr 4, 2014 | 11:18 AM
  #37
dusty1's Avatar
yeah, I think you'd be looking at at least annual replacement on heim.
Old Apr 4, 2014 | 11:20 AM
  #38
ZGPhoto's Avatar
That is the shadiest thing I have ever seen on a D2, do not do that.
(referring to dusty's photo)
Old Apr 4, 2014 | 11:24 AM
  #39
Dane!'s Avatar
Custom castor looks good and performs well, it is about the same price for a 3 link though. Just no rerouting of the exhaust. I'm sure both will climb rocks like a goat.
Old Apr 4, 2014 | 11:25 AM
  #40
dusty1's Avatar
I wouldn't try that hinge set up on a desk chair.
