new rear shock mount location?
Old Apr 8, 2014 | 11:34 PM
  #81
Dane!'s Avatar
Dusty, most commonly used is 2"OD x 25 (1.5"ID) DOM tubing.
Chrome Moly though... that's tempting... I'm sure that's stronger the DOM. I wonder what the cost difference is. I haven't picked up my tubing yet, or even called for a quote. I might take that route if its not too much more... just because, well, because.
I'm thinking about 2 sticks is good enough for the front and rear, with a little(a lot) room for mistakes.
Sorry for the late-ish response. I was trying to fit axles in the back of the D2 without scuffing it up to much... should've taken a picture of em in the rover.
Last edited by Dane!; Apr 8, 2014 at 11:34 PM. Reason: Line spacing....not...correct...
Old Apr 9, 2014 | 04:54 AM
  #82
OffroadFrance's Avatar
Originally Posted by dusty1
I wonder if it has a "nobody wants to play with me" vocalized horn. got to admit I kind of wanted to see more of the 8x8.
There ya go Dusty that'll float ya boat
8x8 defender! - Land Rover Zone
There is always a PITA with everything though, parking the damned thing in a municipal or Walmart car par on a Saturday morning.
Old Apr 9, 2014 | 08:31 AM
  #83
dusty1's Avatar
yeah, I ordered the cm for the low long bars and have standard dom for safer location link. cm for the added strength. safe than sorry. but dom price is cheaper
$14 vs cm $25 for same size.
ordered pre fab brackets and joints from ballistic, but have yet to figure out the best option for bushings at axle... open to suggestions. ballistic has those greasable poly w/ weldable sleeve, but not sure if that is the way to go.
Old Apr 9, 2014 | 08:34 AM
  #84
dusty1's Avatar
definitely something to see.
but only see.
Old Apr 9, 2014 | 11:28 AM
  #85
Dane!'s Avatar
DOM Sleeve
It's DOM tubing with a zerk fitting.... you have the tubing so you could make it yourself. As long as the upper link is adjustable you should be fine.
I might put a small heim right there in the center. Because I was thinking the other day that the bushings are 2.5" wide and the tube is 2" wide. So you'd have to space your center y link thing .25 on each side for it to work. I'm thinking that might compromise some strength. I wouldn't want to do that, especially if you bought cromo tubing.
Daedrix
Apr 22, 2014 04:51 PM
shaggy52282
Apr 28, 2012 05:12 PM
SenatorPerry
Jan 29, 2012 11:19 AM
KingKong8247
May 15, 2011 07:46 PM
