New to Rover
Old Nov 12, 2015 | 06:44 PM
rtonder's Avatar
There is a test port for the fuel rail behind the inlet manifold, just to the right of center as you face the engine from the front. It is like a tire stem valve, only made from steel, with a silver colored cap. Remove the cap, start the engine, and after it stalls, press the valve stem with a small screw driver to see if it releases fuel. If there is fuel at pressure (a spray) the pump is not causing it to stall.
omega17632
Jan 22, 2017 10:22 AM
wisconsinoverlander
Oct 1, 2012 09:34 AM
Ronin005
Mar 7, 2008 05:33 PM
winstonbike
Jun 1, 2005 01:56 PM
BFREE
Apr 25, 2005 01:32 AM
