New speakers
im wanting to get all new speakers because the land rover ones make weird plastic creaking noises but i was wondering if i can keep the stock head unit and run the speakers off an amp and the sub box on the rear door i want to remove the land rover subs and put in new ones if possible i just want everything to look stock
Yes, you can. The factory amp at least in my '04 with the premium sound system does a pretty good job with the drivers in the doors. I have an aftermarket head unit running through the amp to 6 1/2 inch Pioneer 2-ways that I bought for $30 off Amazon. I just cut the feeds to the tweeters and installed them in the stock locations. For the subs, I installed a pair of Kicker 6 inch subs and I'm powering them with a separate amp I installed under the passenger seat. I will eventually make the sub enclosure air-tight but for now it sounds decent. The Pioneers actually made a huge difference on their own. If you are using the factory head unit, I'd start there and see how it sounds. That might be all you need to do.
www.sonicelectronix.com or www.parts-express.com
Those are the 2 i use regularly...............have a fairly hot system in my daily driver...........the Rover is next in line.....:-)
