New springs don't match.
Old Mar 23, 2022 | 04:45 PM
328Driver's Avatar
Default New springs don't match.
New TF 2 inch lift and the springs aren't even close in length.
Old Mar 23, 2022 | 05:02 PM
whowa004's Avatar
More info? The front and rears are not the same length and some brands have different lengths for driver or passenger side..
Old Mar 23, 2022 | 05:15 PM
328Driver's Avatar
2IN TF From Lucky8. What other details do you need?
Old Mar 23, 2022 | 05:20 PM
specops1526's Avatar
They should be different lengths between front and rear. I can't remember which ones are longer. If there is a slight variation between the two front and two rear, then as said above, they are sided for Driver and Passenger sides. The longer one would be for the Driver side. That's the way the OME springs are.
Old Mar 23, 2022 | 07:25 PM
Dave03S's Avatar
They may be labelled if you look closely... FL, FR, RR, RL, etc.
Old Mar 23, 2022 | 08:15 PM
Alex_M's Avatar
There are multiple 2" lifts from TF, but to answer your original question the driver's and passengers side springs are different lengths due to different weight side to side.
Old Mar 23, 2022 | 09:27 PM
04disco2va's Avatar
Had this same problem with two sets TF springs. My springs did not have any labels for which corner and Atlantic British didn’t confirm they should be different lengths from left to right yet my measurements were off no matter what side the springs were on. Also swapped the rears with no change and ended up buying another front pair and using the longer spring of the two to fix the discrepancy. At this point got a little pissed and ordered RTE 3” springs. They are still in the boxes and just looked at both fronts and they are same height. So not sure what the right answer is but feel your pain.
Old Mar 23, 2022 | 09:38 PM
JohnZo's Avatar
Default Front spring specs
The front springs on NAS D1s don't match per spec.
Old Mar 24, 2022 | 06:46 AM
The_OGCJR's Avatar
That is normal!!
Mine were labeled for the tallest front to go on driver side and next tallest to passenger side and so on
Old Mar 24, 2022 | 06:47 AM
The_OGCJR's Avatar
From what I remember reading, OME springs are the same way
