I will go get a new set of plugs. Ordered a leak down tester form harbor freight. Total cost was $48 shipped. The local mechanic wanted $50 to do the leak down test, so now I get a free tool.
Already ran compression check (forgot to mention it). Had 130 PSI.
I would replace the coil pack before a injector.
You still need to remove the intake plenum no matter what and a used coil pack is cheaper than a injector.
Thanks Spike that's good to know. Since I have to take the upper plenum off either way, I'll swap the injector to see if the code moves before I invest any money.
Are the coil packs easy to replace once you have the plenum off?
Before you go and replace the coil, from what I've learned the coils run in pairs. If it was a bad coil pack, you'd be having problems with another cylinder as well.
I just bought a used set of coils for $40 including shipping. Can't go wrong for this price. Will update with results after installation. Thanks for the help.
