New Wires/Plugs and still throwing P304
Old Nov 1, 2009 | 01:35 PM
  #21
Foe's Avatar
Foe
Default Will do
I will go get a new set of plugs. Ordered a leak down tester form harbor freight. Total cost was $48 shipped. The local mechanic wanted $50 to do the leak down test, so now I get a free tool.
Already ran compression check (forgot to mention it). Had 130 PSI.
Old Nov 29, 2009 | 02:35 PM
  #22
Foe's Avatar
Foe
Default update
Finally got around to doing a leak down test. Cylinder 4 checked good with 18-19 PSI of loss. Tried new plug - still throwing P0304
Should I take off the upper plenum and try a new injector? I sure hope it's not the darn coil pack....that looks like a real booger to get out.
Old Nov 29, 2009 | 02:40 PM
  #23
I would replace the coil pack before a injector.
You still need to remove the intake plenum no matter what and a used coil pack is cheaper than a injector.
Old Nov 29, 2009 | 03:19 PM
  #24
Foe's Avatar
Foe
Thanks Spike that's good to know. Since I have to take the upper plenum off either way, I'll swap the injector to see if the code moves before I invest any money.
Are the coil packs easy to replace once you have the plenum off?
Old Nov 29, 2009 | 04:35 PM
  #25
I have not replaced one on a Rover before but yes, they are very easy. Just unbolt it, unplug it, remove it.
Old Nov 29, 2009 | 07:29 PM
  #26
brianb883's Avatar
Before you go and replace the coil, from what I've learned the coils run in pairs. If it was a bad coil pack, you'd be having problems with another cylinder as well.
Old Dec 1, 2009 | 06:19 PM
  #27
Foe's Avatar
Foe
What else is left as a possibility?
I just bought a used set of coils for $40 including shipping. Can't go wrong for this price. Will update with results after installation. Thanks for the help.
Old Dec 1, 2009 | 07:44 PM
  #28
Foe-once you get this figured out PLEASE let us know, this is a common topic with DII's and nobody can ever report a cure.
Old Dec 1, 2009 | 07:47 PM
  #29
Foe's Avatar
Foe
Will do Spike - I owe it to you all for helping me
Old Dec 1, 2009 | 08:49 PM
  #30
BajaXJ92's Avatar
I'm anxious to hear the outcome myself, as I'm battling the same problem on my '96 DI. Its getting worse by the day too....
