New Wires/Plugs and still throwing P304
Old May 23, 2011 | 09:09 AM
  #41
KyShark's Avatar
Originally Posted by DarylJ
A misfire on one cylinder should not make you think coils.
When does it happen? Only in the morning/cold start?
Precisely. Runs rough (assume it's the misfire) until it's run for about 15 and normal temp.
Maybe unrelated, but it's also only starts after the third try (sometimes sooner with full tank and cold start). . . I'm thinking fuel pump on it's way out.
Old May 23, 2011 | 01:34 PM
  #42
DarylJ's Avatar
OK, I remember this issue now (somewhat).
Have you checked on what is in that cylinder in the morning? Coolant or fuel?
It sounds like the typical presentation of a coolant leak into a cylinder.
Old May 24, 2011 | 06:07 AM
  #43
KyShark's Avatar
Did an induction cleaning yesterday and it seems to have mostly cleared up. Also, it's not using coolant, so if it is that it must be a tiny trickle of a leak.
We'll see what happens when I put the magnacores in when they get here from Apex.
Old May 24, 2011 | 09:01 AM
  #44
DarylJ's Avatar
Oh...I though that had been done. In that case, scratch the leak diagnosis. You need to start with plugs and wires. A loose connector on a plug wire will absolutely do the same type of thing. Basics first, then we can panic.
parkerlander
Jun 23, 2013 09:24 AM
pdowning6
Apr 30, 2012 08:38 AM
Foe
Oct 3, 2009 08:34 PM
Rover5150
Feb 21, 2008 10:21 AM
