Newb....911...overheated engine
Old Aug 12, 2010 | 12:23 PM
agthird's Avatar
Default Newb....911...overheated engine
Just bought my 2003 disco II and the lower radiator hose that ties into the plastic junction for the filler and what appears to be the heater hose broke off allowing the coolant to spill out all over the street on my way home....drove with the red overheating light on for a minute at most...okay so what am I looking at, the engine was idling fine when I shut it down just not sure if what to think at this point...any thoughts?
Old Aug 12, 2010 | 12:29 PM
catchthebig1's Avatar
1) buy new hose and hardware
2) fill and bleed with new coolant
3) start car and see if temps are good
that is what i would do.....but i am a newb also....
so i wait to be corrected also......
Old Aug 12, 2010 | 12:36 PM
agthird's Avatar
lol...thanks catch with all this head gasket talk I'm walking on egg shells....hopefully it's that simple...
Old Aug 12, 2010 | 01:12 PM
Jason_B's Avatar
I had a pretty bad over heat when my serpitine belt shredded due to a bad idler pully. I just refilled with coolant mix and I've been good ever since. I wouldn't worry about it too much. Pm me I'd you need help with coolant fill/ bleed steps.
Old Aug 12, 2010 | 01:58 PM
agthird's Avatar
Jason thanks!!
Old Aug 12, 2010 | 03:10 PM
malmberg's Avatar
Since you had one hose fail you should order the hose kit to replace all of the hoses. I would also throw in a thermostat while you are at it. Better safe than sorry.
Old Aug 12, 2010 | 04:07 PM
NiteTrain's Avatar
aluminium engines don't like over heating..even for a minute..if you didn't cause any damage you're lucky
Old Aug 16, 2010 | 10:46 AM
brihite's Avatar
5th Gear
i have a 99 disco ii. for the last 3 days it has been running hot. once it cooled, i started it and there was no heat coming out of vent inside. i bought a new lower hose and a new thermostat from lr dealer. i bled the cooling system by pouring water in the bleed valve (bought new T set-up) until it filled the reservoir. now i have heat and it runs fine with heat on. i let it sit idling for 45 min. yesterday. i drove it about 30 min. yesterday. temp guage never went past half-way, but that was with heat on. when i turn on a.c. or just turn system to off, it overheats after about 10 min of normal driving. i have not been able to get it to over heat while idling though? i don't have any bubbling (boiling) in reservoir when hot but it does let off steam through res cap. i don't have waterfall noise inside. my compressor fan is operating. my top hose gets hot almost immediately. it is 100 degrees plus here in memphis and running the heat isn't that enjoyable. Please help, this is my only car.
Mike, i would love a phone call if you are not too busy. my name is brian. i am at 901-201-9791.
__________________
99 disco ii
2fast4u
LR2
Dec 7, 2009 08:42 PM
zezeze
Aug 3, 2009 02:16 PM
dlkk
Aug 3, 2007 09:12 AM
unco
Dec 2, 2006 06:32 AM
BMWLR
May 12, 2006 01:44 AM
