newbie
Old Mar 5, 2009 | 08:40 PM
jimbo97's Avatar
Smile newbie
hi guys im a newbie in this forum , and i really need your help. i just bought a 97 disco and i was wondering do i have to fill the coolant regularly ,because i didnt see the HIGH and LOW mark on the reservoir tank all i see is an " X " mark . do i have to fill it all the way up or just the half tank?
2. and i just bought a rear view mirror and its from a 98 disco , is it okay if i didnt plug the wires or i still have to connect all the wires back ? or if not , is it going to be a problem?
3. again i need to replace the gear shifter housing because it is all torn out but i dont know how . hehe i know this might be to much to ask of you guys but i really need to get to know my landy better .. plus im a student so im on a tight budget . many thanks guys...
Old Mar 6, 2009 | 09:09 AM
DiscoJag's Avatar
Welcome Jimbo. The coolant level is supposed to be even with the top of the "X" thing in the middle of the reservoir, not to the top. The rear view mirror can be used if not plugged in, but it won't have the auto-dim feature working. On the gear shifter housing, do you mean the part with the PRNDL on it ? I'm not much help on that. You should get a service/shop manual if you are planning on doing work on the truck. Haynes does make one, or you can subscribe to Alldata.com on-line for twenty some bucks the first year and a little less for each year after. It's going to be a little rough keeping a Disco up being a student on a tight budget, but good luck, I love my Disco.
Old Mar 6, 2009 | 10:19 AM
Jawbox's Avatar
Also, if you have to fill the coolant regularly, you might have some real problems on your hands. If your Discovery is in good shape, you shouldn't have to touch the coolant except to flush it every two years.
If your coolant level is dropping you need to find the source of the leak. If these vehicles overheat there is more than a slight risk you might toast the engine. This should be your number one priority. (The good news is most leaks can be fixed for the price of parts)
Old Mar 6, 2009 | 10:37 AM
discoxd's Avatar
yeah sort out the coolant thing first off... replacing parts of the center console are pretty easy, just start removing screws and little panels and before long you will have the whole console out and be able to better access what you are trying to fix... the mirror does not need to be plugged in to continue to function as a mirror, you just wont have the auto dim feature, most older discos dont auto dim anymore any way, they just kinda fogged up long ago... i actually clipped the wires to my auto dim mirror and used them as the power souce for my CB radio mounted onto the overhead bin...
Old Mar 6, 2009 | 11:48 AM
jimbo97's Avatar
Thumbs up sweeett...
thanks for the advise guys... its been really helpfull
Old Mar 6, 2009 | 12:06 PM
AK Rover's Avatar
If you suspect you have a coolant leak take the truck to a mechanic and have a pressure test done on the cooling system. My mechanic charged me a half hour shop time to perform the test.
ashby1
Mar 7, 2005 12:27 PM
gwelland
Feb 9, 2005 04:16 AM
quattro4now
Feb 8, 2005 04:28 AM
flimbo
Oct 2, 2004 05:14 AM
Sarah
Oct 2, 2004 05:10 AM
