Newbie ?
Old Sep 2, 2010 | 07:22 PM
wsroufe's Avatar
Default Newbie ?
I have the read the stickey and post about driveshaft rebuilds. I have a couple questions?
I just bought a 1999 DISCO, 104K. Headgasket was done, but I have records of driveshaft or tranny, etc. I plan on further investigation this weekend. It drives great! No noise, etc. Should I change the Ujoint anyway?
Do you do both front and rear shaft?
Thanks,
Bill
Old Sep 2, 2010 | 07:38 PM
lordmorpheus's Avatar
If your front driveshaft does not have three grease-able u-joints, YES: change them!!!
The rear driveshaft u-joint should be replaced if there is any play in it, or it does not take grease from a grease gun.
Old Sep 2, 2010 | 07:52 PM
wsroufe's Avatar
Default Front
OK I got underneath - looks like it hasn't been done. I will buy parts and get to it. Can you give exact part numbers? Exactly what I need?
Did the factory install ujoints with greaseable joints?
Old Sep 2, 2010 | 08:25 PM
The Precision part numbers for the three joints (and also the one joint on the rear shaft) are 344. The centering ball on the front shaft is a Precision 617. There are other brands that will work, if you just search this forum.
The only grease-able joints from the factory are the front joints on both the front and rear shaft. The two joints that make the double-cardan joint at the rear of the front shaft, never came from the factory as grease-able, even though they are right next to the converter, and get water dripped on them from the A/C evaporator.
ashby1
Mar 7, 2005 12:27 PM
gwelland
Feb 9, 2005 04:16 AM
quattro4now
Feb 8, 2005 04:28 AM
flimbo
Oct 2, 2004 05:14 AM
Sarah
Oct 2, 2004 05:10 AM
