Newbie coolant change question
Old 10-22-2012, 01:14 PM
jwfuller's Avatar
Dexcool if changed frequently in a perfect world may be OK. Allowed for extended stay not so good. Topped off with who knows what even worse. Turns into sludge. Restricts flow of water, like having half a radiator. Motors run hotter. Mechanics can afford new boat payments. Engine design is late 1950's, when oil change interval was 1000 - 3000 miles. Taking that same dirty engine and putting expensive oil in it and running to 25,000 between drain and filter changes not such a good idea. You can run anything you like, but don't go low viscosity when hot (40 or 50 as last number); and change oil every 5000.
Otherwise, Cedric Whistlebritches, infamous Rover wrench wrangler, is waiting for you.
I took my truck to Red Noland, Colorado Springs for a free checkup. I thought the entire 4700 dollar quote was garbage.
I've ended up replacing every part they put on that quote except for the caliper. I figure a dime-length hole in a caliper boot can just wait since I have to replace the entire unit. Some of these dealers may be shady, but I have no reason now to suspect these guys.
AwannaD2
11-01-2012 01:26 PM
collin Barrows
08-28-2011 07:13 AM
junya
08-12-2011 08:24 PM
Disco Alan
05-11-2009 04:15 PM
Quick Reply: Newbie coolant change question
