Newbie owner of '00 Discovery 2 with leaks. Need tips and help.
Hi, first time owner of Land Rover so I know very little about the car. Have been doing a lot of reading and kinda know whats going on, but not really
So, I bought this 2000 D2 from an old nice lady who isn't able to drive any more. The engine sounds like brand new, 100K mileage, oil changed regularly at Midas , serviced at local Land River in DFW, Texas.
The symptoms are of cracked head gasket - overheating, losing coolant. So initially I was going to use the short cut and use one of those head gasket treatments and drive 500 miles with it. BUT, after looking underneath the car I see that there is oil on a drivers side. My thought is its a pan gasket .. or not. Can you give your 2 cents what else could this be.
PS: after reading some more, I guess I will be better off paying indy mechanic and change head gasket and pan gasket at the same time rather than doing the "head gasket sealer". And if anyone has recommendations for LR mechanic DFW area, I would be greatly appreciate it.
Are you sure that these leaks are even coolant that leaked out there? It looks like oil to me. Is it sticky and does it taste sweet? If so, its coolant; if not, it's oil of some sort.
I replaced head gaskets in my old 1988 Range Rover with the 3.9l, and it wasn't too bad, but I had the engine open for about two weeks of evenings and weekends. I imagine a 4.0l is about the same.
Scott
Scott
Scott
Scott
The oil leak leads me to believe there is a pan gasket bleed somewhere.
so I had my mechanic stop by my workshop/garage today and he didn't noticed any signs of gasket problem. What he saw is a lot of air in the hoses and used bleeder valve and extra distilled water to get rid of it (what he could with out evacuation tools). Then we drove the car for about 15 minutes and everything seemed to be normal. No overheating even with full AC blasting. Then we both went home and I came back to garage 2 hours later hoping to drive the car home. This time I drove it for 2 minutes and it started to overheat. I pulled over, waited it to cool off and took it back to garage. "Service engine soon" light came up as well. My mechanic is going to bring his diagnostic tools next weekend and read the messages. Any idea about this sort of behavior? Thanks for all your help.
Too bad about overheating again. That's very frustrating.
The best diagnostics are the engine's own. Many auto parts stores will read codes for free if you don't have your own ODB code reader. However, code readers aren't very expensive, so I'd recommend you buy your own. There are OK readers at Harbor Freight with free on-line updates. There are good and very inexpensive code readers on eBay too, even some with Bluetooth with free apps you can run on a smartphone. There are lots of options.
Good luck.
Scott
Good luck.
Scott
