Newbie Question on Shocks/Springs
Old Oct 29, 2013 | 11:26 PM
jmiles's Avatar
4th Gear
Default Newbie Question on Shocks/Springs
Greetings,<br />
So I bought a 03 Disco after always driving FJ80s. Must say, I'm a fan. 65k miles. I recently replaced the Rotors and Brake Pads, fixed a leak in the Transfer Case, changed the plugs and wires (not fun), seafoam induction (fun), and did many other random tune-up and fluid stuff. Must say I have learned a lot on this forum. So many thanks.<br />
<br />
My question is though. I had a leaky airbag in the rear and decide to convert to springs. I fitted a Heavy duty set from Brit Part because I will be adding an ARB bumper and a roof tent in the near future. They are the super gaz hd with a 1.5 in lift. However, and this may just be lack of experience but, I'm hearing a good amount of spring noise every time I go over a bump. If I rock the truck back and forth it seems fine. Did a small bit of offroad and it handled alright. Everything looks right underneath. But just that &quot;boing&quot; noise over bumps is a bit odd to me. Any thoughts? Thanks
Old Oct 30, 2013 | 01:33 AM
Dave03S's Avatar
What shocks did you use with those HD Super Gaz springs?
Old Oct 30, 2013 | 08:28 AM
drowssap's Avatar
did you switch the rubber spring isolators over?
Old Oct 30, 2013 | 04:22 PM
jmiles's Avatar
4th Gear
I used the Super Gaz HD Kit. Came with front and rear Springs and Shocks. I did install the rubber spring isolator in the rear. I also made sure that both pigtails on the springs pointed to the driver side.
Could it just be that there isn't enough weight on the vehicle yet? Seems to ride smooth, just has a weird spring noise when I go over bumps slow. Thanks
Old Oct 31, 2013 | 07:25 AM
drowssap's Avatar
are you sure all the coils seated correctly in thier pockets?
Old Oct 31, 2013 | 02:11 PM
jmiles's Avatar
4th Gear
Pretty sure. Everything looks right. Aside from the bottom mount and isolator on top, I didn't add anything else. Almost want to toss some medium coils on to compare.
andrewmcoffin
Feb 19, 2008 10:53 AM
adowgiert
Dec 10, 2007 08:15 PM
bklahl
Aug 15, 2007 08:19 AM
johnnybob06
Aug 13, 2007 07:31 AM
newBrover
Mar 24, 2007 07:11 PM
