Newer years LandRover wheels... do they fit ?
Old Jul 17, 2023 | 09:04 AM
Externet's Avatar
Question Newer years LandRover wheels... do they fit ?
Hi.
See often used newer LR wheels with tires for sale, do they fit the Disco2 hubs ? Newer years are bigger diameter, 17" ; 18" ; 20"
With lower ratio tires do they match nearly the original ride height ?
Anyone running on them ? What about RangeRover wheels, do fit ?
Old Jul 17, 2023 | 09:26 AM
Best4x4's Avatar
Must get a set of good hub centric rings.
Old Jul 17, 2023 | 10:24 AM
Externet's Avatar
Thanks. I did not know what ''hub centric rings" are.
Searching; seems fills/fit a larger diameter hole on the wheel to smaller diameter hub. Not much of a mystery, even saw a diagram ! Great ! I assume the spacing for bolts is the same.
Old Jul 17, 2023 | 03:52 PM
Best4x4's Avatar
5x120 I've run LR3/LR4/RRS/RR wheels on a D2 with hub centric rings & zero issues. You also have to use the newer LR lug nuts vs D2 lug nuts.
Old Jul 17, 2023 | 07:25 PM
Extinct's Avatar
These fit on the d2 with no adapters other than the oem lug nuts
teghogh
Nov 28, 2022 07:48 AM
Colorado David
Jul 18, 2014 12:42 PM
BayouRover
LR4
Sep 17, 2013 10:41 AM
KSIGTTU
Dec 9, 2009 05:53 PM
allblackhse
Sep 5, 2009 06:28 PM
